Power window issue
Old Dec 24, 2008 | 02:44 PM
EdW's Avatar
EdW
Default Power window issue
Got a 99 XC70 and today the drivers side power window quit going up and I have a couple of questions:
1. Do you have to remove the door panel in order to get the power window switch cluster out?
2. If 'yes' to #1, how do you remove the door panel?
Also, if anyone has any pointers on what may be causing this or how to fix it, I would love to hear it.
Old Dec 24, 2008 | 06:14 PM
Default RE: Power window issue
The switch assembly's are very common to go bad.
I slide a hook tool into the switch assembly and pull it up and out.
Old Dec 25, 2008 | 08:03 AM
Psaboic's Avatar
You shouldn't have to remove the door panel to get the switch out. Tech is right, the switches go bad often
Old Dec 27, 2008 | 09:25 AM
EdW's Avatar
EdW
Thanks for the replies. I will pull it and replace.
bucktooth78
Sep 22, 2018 05:41 AM
HoopyFrood
Jun 3, 2015 10:28 AM
reecesp1eces
Feb 2, 2014 08:44 PM
John Clawson
Oct 24, 2012 05:56 PM
1998v70
Aug 10, 2010 09:15 AM
