Rumble under car between 20 -30 mph
Old Nov 27, 2007 | 07:54 PM
ramp's Avatar
Default Rumble under car between 20 -30 mph
2001 V70XC 170,000 wife mobile
I do not drive this car often so the Mrs. tells me that the car isn't right. While accelerating from 20 to 30 there seems to be a wheel out of alignment. Front left side with vibration transmitted to steering wheel and under ones right foot. Drive shaft, front axle CV,,any ideas?
Old Nov 27, 2007 | 09:12 PM
Default RE: Rumble under car between 20 -30 mph
I would try to remove the driveshaft and see of the vibration goes away.
If not check the tires.
Old Nov 28, 2007 | 05:39 AM
ramp's Avatar
What do you mean remove the drive shaft?
Old Nov 28, 2007 | 08:39 AM
Psaboic's Avatar
Also, try swapping the tires front to rear. That is an easy way to tell if it is a tire or something else.
Old Nov 28, 2007 | 05:53 PM
ORIGINAL: ramp
The driveshaft from the front Diff to the rear Diff.
joshfrigmont
Jul 19, 2014 04:58 PM
cja1983
Jul 5, 2012 05:50 PM
jimihend2
Jul 12, 2010 09:59 PM
MSLamb5
May 20, 2010 09:45 PM
lienmarine
May 14, 2010 07:20 PM
