Stalls when cold
Old Feb 13, 2005 | 09:33 PM
jason's Avatar
Default Stalls when cold
I have a '98 XC70 which has just started stalling when cold. If I nurse the throttle and restart (a few times),until warm, it runs well. The check engine light has come on. Short of a trip to the dealer, are there a couple key things to check? I'm reasonably mechanically inclined. I also intermittently see the "up" arrow.
help,
Jason
Old Feb 13, 2005 | 10:20 PM
jason's Avatar
Default RE: Stalls when cold
Oh yeah, I forgot to mention - It will stall and die if I keep the RPMs at any steeady state above 2500. In other words, if I nurse the accelerator, I can keep the engine running well enough to drive. Oh well, I guess it's off tto the dealer for an Engine Code check. Cross your wallets boys, it's going to be a bumpy ride!
Old Feb 14, 2005 | 12:02 AM
If you are near and Auto Zone or Discount Auto parts they pull codes for free.You might have a bad coolant temp sensor or a bad mass flow sensor.But you need to have the codes pulled first.
Old Feb 16, 2005 | 03:10 AM
jason's Avatar
Default RE: Stalls when cold - fixed
You were right! It was the Mass Airflow Sensor. I feel better being more informed.
thanks
Old Feb 16, 2005 | 10:39 AM
Im glad you got it fixed.Im also glad I could be here to help.
WithRandomPrecision
Nov 14, 2010 10:00 PM
rainman14624
Sep 20, 2010 09:22 PM
Misfit
Dec 28, 2009 08:30 AM
537playing
Nov 8, 2009 02:43 PM
850forum
Oct 11, 2007 12:03 PM
