Turn Signal failure
My 1998 V70-xc just started acting up. the turn signals flash real fast ( not like you have a bulb out) then stays on steady. Pressing the 4-way flasher switch causes them to flash a few times then stops. I can hear the relay behind the 4-way switch chattering. All turn signals light but i get the chatter then stop. Any body else have this experience?
Gary
Gary
Turn Signals
The turn signal's work, its's something with the flasher unit. If I manually flip the turn signal lever the lights come on but dont flash, some times they do for a couple of flashes then chatter quickly then go steady. I read on another thread that the flasher unit is the problem but how do you access?
Thanks for your input. Gary
