V70 AWD
Old Oct 4, 2005 | 03:18 PM
jaymac's Avatar
Default V70 AWD
Hi Just got a 1998 V70 awd noticed a soft whine/whistle noticable at startup presume it is there allthe time but not noticable once speed is up to 20-30 ish Is this the nature of the beast? all help appreciated
Thanks Jaymac
Old Oct 4, 2005 | 08:57 PM
Default RE: V70 AWD
That might be the nature of the beast.
What kind of service work has been done and how many miles?
Old Oct 5, 2005 | 09:08 AM
jaymac's Avatar
Default RE: V70 AWD
Thanks All service has been done at required periods by volvo the car has just done 48000 miles the noise is almost fanlike but no fans going.
Old Oct 5, 2005 | 09:45 PM
Default RE: V70 AWD
Ok I just wanted to make sure the car didn't have alot of miles on it.
I think it is just the nature of the beast.
Old Oct 6, 2005 | 09:22 AM
jaymac's Avatar
Default RE: V70 AWD
Thanks Tech
Jaymac
Old Feb 13, 2006 | 03:32 AM
skamper's Avatar
Default RE: V70 AWD
I have the same car, same year, & same problem, A humming/whinning sound when cold on start up for maybe 10-60 seconds under load or when reving. no noise when warm. The noise appears to be from around the timing cover area or belts I thinking Power steering pump? Whirling sound i get sounds like a noisy ford power steering pump?. However I can't be 100% sure I'm Also open for ideas. Also have a question about my 98 v70 xc awd. Does any one who drives a v70 turbo know if the turbo is quiet ? I don't hear it spooling up or whinning under accel or load. It dosnt feel like a turbo car? is this a normal for the v70 turbo
Thanks Greg q
Old Feb 13, 2006 | 09:02 PM
Default RE: V70 AWD
ORIGINAL: skamper
Thanks Greg q
Pull the timing cover and inspect the timing belt idler pulley and tensioner pulley. If you see any grease at all on the pulley or seal then you need to have it replaced.
How many miles are on the car?
LarryNH914
Mar 5, 2018 12:11 AM
laughers
Jun 28, 2015 11:06 PM
awdMN
Nov 28, 2010 09:08 PM
vfgilber
Apr 14, 2010 07:43 AM
shrekthefearless
Dec 26, 2008 10:42 PM
