Sponsored by:
Sponsored by:
xc90 lowbeam headlight turns off when car started
Old 01-25-2013, 10:13 AM
jaippolito's Avatar
Default xc90 lowbeam headlight turns off when car started
its been 0 degrees or less in Maine for last 4 days (not sure if cold weather is causing this).
A couple days ago i started xc90 after work and the driver side lowbeam headlight went out. Thought it was bad bulb. Later, I turned car off and then turned key to ON position, headlight works.
But, as soon as I start the car the driver side lowbeam headlight flickers (once car is started) and goes out and stays off. Its been so cold that i haven't done much other than check that the harness to headlight fixture isnt loose.
Does this sound like a relay issue? I can't seem to find info that the headlights have a relay. The fuse for lowbeam headlight is fine (checked it last night).
Old 11-25-2013, 12:02 PM
brad6kids's Avatar
Good Monday. I have the exact same issue on my '05 xc90. fuse is good. did you solve your problem? Thanks!
Old 11-25-2013, 08:57 PM
yyc xc90's Avatar
It switches from xenon to regular depending on daylight sensed Canadian vehicle. I never have to touch light switch.
Old 11-26-2013, 07:58 AM
jaippolito's Avatar
in my case, i ended up putting a new bulb in, even though the one in there would "sort of work". So, I would recommend trying a new bulb. To test, if the bulb on the other side works, you can take that one and swap them to see if it is the bulb.
Iggyomega
04-10-2020 07:23 AM
Stb7
11-06-2013 09:12 AM
ohryan19
05-18-2010 06:36 PM
ben0747
11-09-2008 08:45 PM
Quick Reply: xc90 lowbeam headlight turns off when car started
