2005 XC 90 Parking/Emergency Brake Problem
Old Apr 10, 2019 | 09:12 AM
  #21
chrisd111's Avatar
Default old style pedal?
Do you have this type or the other? The cable wraps around a drum.
File Type: pdf
Old Apr 10, 2019 | 09:18 AM
  #22
Toneloc's Avatar
Default Parking brake pedal mechanism
Not this one Chris. On mine the Cable simply hooks on to a cut out on the lower part of ratchet.
The part I found lying in the footwell unattached to the pedal mechanism looks nearly like a silver paper clip that someone has untwisted. I assume it some how attaches to the ratchet and prevents the cable dropping off. But I just can't see how or where it attaches (and I'm a mechanical engineer! &#129315.
Thanks again.
Old May 10, 2019 | 01:44 PM
  #23
alf's Avatar
alf
Folks - Volvo's parking brake shoes are special in the following way. A typical brake shoe has a half arc of brake shoe material that is a constant thickness...about 3/16" thick or so. On a volvo xc90 each brake shoe has a section that is ground flat symetric to half way along the arc. I bought new aftermarket brake shoes and they just would not hold. I then went to volvo and bought brake shoes and the only difference was the flattened surface half way along the arc. Like someone ground it off. I learned this from an INDIE Repair shop. The shoes work great with the flat spot on them.
Amir PoostPardaz
Sep 19, 2018 07:50 PM
jef59
Aug 5, 2015 08:14 PM
steved1966
Jan 18, 2011 04:17 PM
dan2286
Apr 7, 2009 01:29 AM
chuckc121
Dec 23, 2008 12:21 AM
