2005 XC90 V8 engine noise
Old Aug 27, 2008 | 11:21 AM
fremon39's Avatar
Default 2005 XC90 V8 engine noise
I have a 2005 XC90 V8 with 27K miles. When started from cold it make a lot of noise which stops after about 5 seconds. Then it idles quietly. But if you rev it up
the noise returns. It sounds like an accessory drive idler or possibly a cam chain issue. It sounds like it is coming from the valley area. The engine oil level is OK and the power
steering fluid level is OK (PS pump is in the valley). Is this normal? Or is this a common problem. If so does anyone know the fix?
Thanks
Old Aug 27, 2008 | 01:38 PM
atornquist's Avatar
Default RE: 2005 XC90 V8 engine noise
Hi. With only 27K miles and less than 5 years this should be covered under warranty. I would take it to your Volvo dealer.
miki425
Feb 24, 2022 05:47 AM
95RioRedCobra
Jul 3, 2018 11:25 AM
JD_xc90
Nov 18, 2014 03:31 AM
GadgetRick
Apr 28, 2013 12:23 PM
kartman01
Apr 14, 2006 10:31 PM
