2006 XC90 Headlights poor
My 2006 XC90 came from the factory with Bi-Zenon headlights which are okay on low beam but very poor on high beam. They are the type of headlight that only tilt up the bulb for high beam so it is always one intensity for low and high. I like really good light for highway travel. Has anybody replaced these headlights and if so what did you use - any other ideas?
You might be able to upgrade to a higher power (55w) setup as I think the OE is 35w. That would involve replacing the ballast and bulb. I am not sure if the onboard computer would play nice though due to the higher amperage draw. Maybe someone has done this kind of conversion and wants to respond.
Another option is to add auxiliary driving lights like PIAA or Hella.
The other thing to consider is perhaps the headlight housing has hazed. I don't know about yours but I have seen many XCs with clouded headlights.
Uh... all XC90s have specific high beam bulbs... The xenons are just tilting up in addition to them... Are you sure your bulbs are working, and did you turn the light switch to the 12 o'clock position?
Bulbs: 2005 VOLVO XC90
Here is the 2006 manual...same thing 2006 VOLVO XC90
From 2002 to 2012 there have been 3 different types of headlamps:
Halogen (2002-2012): http://cdn0.autopartsnetwork.com/ima...m9075150-1.jpg (black housing)
Bi-xenon (2002-2012): http://www.webcarnews.com/ressources.../11964-1-5.jpg (silver housing)
ABL (2007-2012): http://www.njuskalo.hr/image-bigger/...a-11850279.jpg (active bending low beam projector)
Check your owners manual. There are high beams, low beams, parking lights and blinkers in all of these lamps.
I've noticed this with my 2005 also. The inner bulbs do not seem to go on (even when high beam is activated).
I noticed other similar threads on this site: https://volvoforums.com/forum/volvo-...97/#post336960
Is this as designed? Or a problem with the high beams?
Attached is a pic of how my headlights look as both high and low beam.
mrgreen, my lights look exactly as your photo. The inner light is on as a daytime running light so, in answer to your question andreasb, the bulb is functioning. In fact the inner light while on during the day is not super bright so I can not see it assisting as a high beam. I would like to see if this thread can get a response from a dealer or Volvo tech as I am sure they have seen this before. This is likely a design flaw but how can it be improved?
Hmmm...could be some differences between US and EUR spec cars then...? Sounds a bit strange that they don't have seperate high beams, as the xenons won't generate enough light output by themselves... I would check this with your Volvo dealer.
For those that DO have separate halogen high beam lamps, the solux upgrades are amazing for high beam...and they're street legal.
If my high beams included the inner light I would upgrade to Solux bulbs in a second. I do not have that luxury so does anyone out there know of an upgrade option for just he Bi-Xenon part of the headlights or can the daytime running lights (inner headlight) be modified to accommodate a better light. Alos to consider - is the upgrade compatible with the computer so the additional electrical demand does not run an error?
No I have not had any replies with a solution. I am also on the Swedespeed Forum and have not received any workable ideas. It is hard to imagine that with such an obvious flaw there has not been someone (including Volvo) with a solution. Even an outright replacement of the entire headlight component would be an option for me. My wife has the 2012 XC70 T6 which has amazing headlights which only furthers my resolve to find an alternative to my current setup. I am surprised that a company such as Volvo that has its reputation based on safety would not search for a solution for what is an obvious deficiency and safety issue.
I have a 2006 XC90 and noticed the same thing. One small thing to add... The position of the light switch matters.
If left in the "full auto" mode, Xenons come on when dark, otherwise the DRL's come on. High beams will not stay on, but will automatically default to low beam. I'm assuming this is to save wear and tear on the Xenon bulbs.
If left in the "on" mode, Xenons stay on all the time, DRL's never come on. But at least the high beams will stay in the up position.
I too am puzzled with this functionality.
the US and EU have totally different headlight rules. generally the EU spec lights are more effective and the US are designed to be more idiot proof (example, EU lights have to be cockpit adjustable to adjust for different loads but this is not allowed in US because they think people will aim them wrong). and in the US fog lights have to be wired so they only come on with low beams (you can't independently turn on fogs only). it used to be even more different (example, US for a time required sealed beams where you had to replace the whole housing not just bulb, and Euro allowed glass lenses which don't cloud while the US requires them be plastic).
mpc - I have the same exact set up on our 2004 as you have. I didn't see a response from you to the question 01_fast_ride posted about hazed covers, and I ask only because Ive noticed on ours the towards the top of the lamps, its becoming cloudy, but hasn't seriously affected the lighting......yet! Ive seen a ton of lamps on e-bay, just not sure about the modification part
Swer
Jan 9, 2015 09:50 AM
fundunski
May 25, 2008 01:47 AM
