2006 xc90 running rough
Old Jun 5, 2019 | 09:05 AM
green2man0's Avatar
Default 2006 xc90 running rough
My volvo started acting funny the other day. It died coming off the highway after a 12 mile trip. It would idle fine after i restarted but had almost no throttle response. Luckily my shop is only about a half mile from the exit. I limped it over there and started checking for what could be wrong. I found the intake tube had detached from the airbox. I figured that makes sense...maf reading was off and was getting unmetered air so it probably went into limp mode. I reattached the tube and cleaned the maf sensor with the crc maf cleaner. Since reattaching it has been starting terrible. It surges, dies, surges, dies, almost no throttle response until a minute or two and then once it gets going it seems to drive fine. I checked the maf heated element and it doesn't look burnt out (both wires are still intact). I've ordered a new maf sensor. Do you think that will get it fixed? 2006 volvo xc90 4.4l. I also cleaned the throttle body with carb cleaner and got a bit of carbon off from around the blades as long as the tube was off. Is there anything else I should be checking? It had a brief CEL...but apparently the heat in the area cooked my OBDII scanner so I don't have codes for you all. I have a new scanner on order as well. Before it died coming off the off ramp everything was normal...no hesitation, started good, ect.
Oh I also reset the ecu....pulled battery cables and left them off for a half hour touched together.
Old Jun 5, 2019 | 05:33 PM
green2man0's Avatar
Well I just got back to my shop and fired up the volvo and it fired up perfectly...no hesitation, no studder, rpms went to about 1500 for 20-30 seconds as usual and then settled to 650rpms.
Zippy83
Jul 6, 2024 03:35 PM
442john
2001-2013 model year V70
Oct 14, 2018 08:45 PM
betsycam
Oct 14, 2015 10:38 PM
flmudshark
Feb 22, 2014 08:39 AM
grndslm
Jul 7, 2012 03:09 PM
