2006 xc90 won't start but cranks
Old Aug 2, 2020 | 03:53 PM
Quil26's Avatar
Default 2006 xc90 won't start but cranks
Owner of a 2006 xc90 4.4 v8 car was driving fine ran low on fuel one day wouldn't start I put some fuel in after a couple tries it started I have also been using it to jump my other car and now my battery is dead and when I try jumping the xc90 it cranks with no start showing pcm code but showing prior to problem have changed spark.plugs and coil still not starting at a lost not sure if I should change alternator, or fuel pump and I cannot locate pcm
Old Aug 7, 2020 | 08:30 AM
schumicat's Avatar
spray starting fluid in the intake. that will tell you if it is a fuel issue. changing alternator would make no sense.
dodgerdogg
May 19, 2020 11:20 AM
raye321
Jul 19, 2019 08:52 PM
turbo matt
Feb 26, 2019 02:11 PM
backyardbill
Oct 29, 2015 08:59 PM
Zumrak
Dec 5, 2009 03:04 PM
