2013 How to tighten bolt for Alternator Drive Gear READ side
Old Feb 4, 2022 | 07:48 PM
eloteman187's Avatar
Default 2013 How to tighten bolt for Alternator Drive Gear READ side
I have the issue where the bolt on the drive gear on the READ side loosened. I have a new gear but am unable to torque it. When I apply force it turns the READ system and the serp. belt accessory pulleys. How do I hold this gear to get proper torque?
The gear I am trying to hold to torque: https://usparts.volvocars.com/p/Volv.../30750136.html
Old Feb 4, 2022 | 07:59 PM
Did you solve the problem as to why the bolt came loose?
The bolt comes loose because the one way clutch on the alternator is bad. If you don't replace the pulley in the front of the alternator - you will have a loose drive gear bolt again shortly. (been there, done that)
Old Feb 4, 2022 | 08:10 PM
Yes, alternator clutch replaced!
Old Feb 5, 2022 | 06:48 AM
@hoonk Any tips on stabilizing the gear to get it torqued?
Old Jan 31, 2023 | 02:06 PM
Skandaz29's Avatar
Hello sir, I have same problem, did you solve the problem?
Jones503
Aug 1, 2020 04:49 PM
AutoNaut
Aug 21, 2016 12:33 AM
newenglandsavages
Jan 25, 2013 08:46 AM
PlattytheVolvo
Apr 27, 2009 10:43 PM
TheRev240
Aug 6, 2008 11:02 PM
