2014 XC90 no headlights, no relay, no fuse just CEM
Old Mar 16, 2025 | 04:39 PM
joseph capra's Avatar
Default 2014 XC90 no headlights, no relay, no fuse just CEM
Last week one headlight went out dash shoed Low Beam Failure. then BOTH low beams went out ( I have H11 and H7 Halogens). Found no fuses blown, bulbs OK. Found NO RELAY AT ALL! Apparently the CEM performs as both fuse and relay in 2013-14 XC90's. So I disconnected the battery in hopes of clearing codes in the CEM.......now my high beams don't work, either!
Anything else I can try short of arson?
What will it take to diagnose why I have no headlights?
Any help will be appreciated.
Did volvo substitute a thousand dollar CEM for a $1 fuse?
Old Mar 16, 2025 | 05:05 PM
Fuse 22 and 23 on the CEM are for the high beams -
If a headlamp bulb shorts out - the CEM will cut off power to that circuit, (like a circuit breaker) and set a code in the CEM. You need to use a compatible scan tool and check for CEM codes. After erasing them (and replacing the bulb/s) The CEM will restore power to the circuit/s.
Old Mar 20, 2025 | 07:05 PM
I have replaced the low beam bulbs ( the dash warning shows low beam failure)
How advanced a scan tool do I need to erase the headlight short code in the CEM to restore power to the headlights?
Old Mar 23, 2025 | 02:18 PM
you need a tool that can read the chassis code set. Most tools read just the powertrain and some do the ABS codes as well. You can try going to a dealer or a Volvo friendly tech or see if you can borrow a scanner from a big box store like Autozone. I've local indys who will do obd 2 scans for free and some dealers.
aks1994
Dec 10, 2019 02:41 PM
Sirbri
Dec 9, 2019 03:09 PM
jharvey3
Jun 6, 2019 12:03 PM
Lone3wolf
Nov 21, 2018 09:59 AM
Ed Coykendall
Oct 18, 2014 08:22 PM
