2016 XC90 Outer Tie Rod Removal
Old Apr 10, 2024 | 06:25 PM
Playmaker's Avatar
Default 2016 XC90 Outer Tie Rod Removal
I am having a heck of a time try to remove a bad outer tie rod end on my 16 XC90. I have tried heat, some tapping of the bolt and a 3 arm puller to force the bolt downward. Because of the aluminum knuckle I am leery of putting too much pressure with the puller. I have sprayed plenty of PB blaster. I see Volvo has a hydraulic tool to remove but it's $400...
Anyone have any experience with the removal of one of these on their SPA platform XC90?
Old Apr 18, 2024 | 07:16 PM
Niklas11Braun's Avatar
Maybe, try using a pickle fork. Another option you can try is using a ball joint separator or a tie rod separator tool. These tools can help you loosen stubborn tie rod ends without damaging nearby parts.
Some mechanics also recommend using a vibrating tool, like a pneumatic or electric chisel, to shake off corrosion and make removal easier.
madymo3d
May 22, 2019 07:23 PM
rocket2222
Jan 3, 2015 06:58 AM
sealer2050
Jun 7, 2013 09:43 PM
chachouu
Feb 5, 2010 09:18 PM
benithegreat
Jul 8, 2008 01:44 PM
