2019 Volvo XC 90 tire light
Old Oct 18, 2020 | 04:18 PM
keeganpvamu's Avatar
Default 2019 Volvo XC 90 tire light
Good evening
I am looking for a bit of help. My XC90 low pressure light keeps coming on about once a week. Each time this happens I have stopped and had the tire inspected and the tire is fine and so is the pressure. Any idea what is going on? I think I have indirect TMPS system. This last time the guy took tire off put in water and saw nothing.
Old Oct 20, 2020 | 12:46 PM
The newer (post 2015 or so) TPMS systems have the computer check for differences between wheel speeds (ie if a tire is low on pressure, its rolling circumference is smaller than the rest and it spins faster). Things that could cause that are 1) one tire that is worn more/less than the others 2) a wonky wheel speed sensor 3) electrical connectore/wiring issue or fault within the ABS computer Assume you are correctly resetting the warning light - if not sure, it may be worth a dealer visit for a scan.
Kristi Ford
Nov 22, 2017 06:48 AM
mcelhinney.c
Apr 17, 2012 05:03 PM
mga56grg
Jan 19, 2012 08:01 AM
mga56grg
Apr 30, 2011 08:38 AM
Scott3985
Jul 17, 2010 07:54 AM
