alternator replacement
Old Jun 26, 2008 | 09:17 AM
potsiewebber's Avatar
Default alternator replacement
I searched but didnt find any helpful posts. Can anyone help me with the procedure to replace an alternator on an 03 xc90 please? I also have to replace a rear shock and could use some helpful hits with that as well.
Thanks,
James
Old Jun 26, 2008 | 07:09 PM
Default RE: alternator replacement
For the Alt once you have disconnected the battery and have the belt off remove the power steering pump. You will most likely have to remove the upper hose to fold the pump over out of the way. Then there is one screw going in from the front by the belt area. The other 2 mounting screws are under it. But you will have to loosen the bottom bolts on the A/C compressor then remove the top 2. Then remove the wires from the back of the alt and slide it out. Sometimes it can be a pain to get it al the way out as well.
Old Sep 12, 2009 | 01:54 PM
trev0006's Avatar
Originally Posted by tech
For the Alt once you have disconnected the battery and have the belt off remove the power steering pump. You will most likely have to remove the upper hose to fold the pump over out of the way. Then there is one screw going in from the front by the belt area. The other 2 mounting screws are under it. But you will have to loosen the bottom bolts on the A/C compressor then remove the top 2. Then remove the wires from the back of the alt and slide it out tires. Sometimes it can be a pain to get it al the way out as well.
Thanks for the info, this will be my weekend project.
the.one
Sep 13, 2011 08:37 AM
surlyredhead
May 24, 2009 10:25 AM
geo81mm
Apr 23, 2009 07:10 PM
realtor123
Oct 13, 2008 09:12 AM
jvolvo850
Oct 10, 2008 04:23 PM
