Alternator replacement 2004 S60R
Old May 19, 2009 | 08:30 AM
surlyredhead's Avatar
Default Alternator replacement 2004 S60R
I am in the process of replacing the alternator on my '04 S60R, I have the power steering pump out and the compressor bolts are loose, but there doesn't seem to be enough room to physically remove the alternator. Any tips would be appreciated! Thanks
Old May 19, 2009 | 07:22 PM
Did you loosen all 4 of the compressor bolts?
Old May 22, 2009 | 08:49 PM
Once I loosened the power steering pump bracket and moved it, there was plenty of room, thanks!!!
Old May 22, 2009 | 09:56 PM
Glad you have it under control now.
Old May 24, 2009 | 10:25 AM
mcleantmw's Avatar
When I replaced the alternator on my 04 S60, I also had to remove the coolant hose that goes into the radiator above the power steering pump and alternator.......there was just no way I could angle that heavey alternator around that hose........if you were able to do so, good on ya!
Docman
Mar 23, 2011 04:23 PM
Never-Enough
Feb 28, 2011 09:49 PM
CM2RAS
Oct 18, 2008 09:01 AM
92volvo960
Jan 20, 2007 04:13 AM
VinUnleaded
Nov 17, 2005 03:17 AM
