Brake lights
Old Sep 17, 2008 | 05:35 AM
corkvolvo's Avatar
Default Brake lights
HI.I have a 2005 XC90 and the brake lights are staying on even when the keys are out of the ignition.I have removed the brake light switch under the steering wheel but have had no joy .Any suggestions?
Old Sep 17, 2008 | 06:33 PM
Default RE: Brake lights
If you press the button in on the brake light switch do they go off?
Also what position is the headlight switch in?
Old Sep 18, 2008 | 04:47 AM
corkvolvo's Avatar
No.The headlight switch is in the off position.The only way to turn them off is by dissconnecting the battery.
Old Sep 19, 2008 | 06:32 PM
Maybe the brake light switch is bad.
Old Sep 20, 2008 | 03:56 PM
m1964's Avatar
You can check the switch -if the button is pressed the re should beinfinite resistance bet. terminals.
aznyaz
Jan 9, 2015 02:38 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
Scott V
Jul 21, 2013 02:28 PM
Mellott
Jun 13, 2011 11:41 PM
chrystald423
Mar 27, 2010 08:05 AM
