Broken Console Lid
Old Aug 5, 2012 | 12:39 PM
oldblues's Avatar
Default Broken Console Lid
I managed to repair my console lid I can't seem to upload photos but if anyone has need of this repair I can probably explain how I did it.
Old Aug 7, 2012 | 09:19 AM
msupepper's Avatar
I'm interested, as my lid is broken at the hinge. I hear it's a common failure on these vehicles.
Old Aug 8, 2012 | 05:04 AM
oldblues's Avatar
I will try to draw up a diagram and take some photos and email them to you or maybe someone here could help post the photos. I will try to do that after work today. I tried to write up instructions but I think a picture will be better.
Old Aug 8, 2012 | 06:20 PM
oldblues's Avatar
Default Link for photos
Pictures by ngteleblues - Photobucket
I used nylon bushings sold at home depot and Lowes as spacers. You may have to reduce their diameter to fit in the steel clips that are mounted on the axle. The original molded bushings are what broke on my console lid. It was necsessary to grind out the remaining bits of the old bushing to have a nice flat surface for the new bushings or spacers. I tried to reinforce the interior of the plastic "clamshell", for lack of a better term, with epoxy putty. You should drill the holes for the screws before you completely remove the old bushings as they will act as a guide so the holes will line up with the other half of the clamshell.
So now I need to find nicer looking screws like black anodized variety. The zinc plated ones aren't pretty but they work for now. The acorn nuts on the inside look pretty good. Someone can probably come up with a better solution but I hope this helps. I think the machine screws were 1.5" long and I had to shorten them to about 1.25" They just need to fit the hole in the spacers. Sorry but this was all trial and error and no measuring.
Old Jul 19, 2013 | 08:41 PM
bgilliam's Avatar
Or you can just use the slow setting epoxy and you not have any holes. Mine broke 3 years ago and still good. Just another option
beano5892
Jan 19, 2015 09:00 PM
Cracker39
Feb 11, 2014 06:48 PM
melkavitch
Dec 19, 2010 04:52 PM
AndrewClarke
Jun 1, 2009 06:43 PM
gstevens2
Nov 3, 2008 12:40 PM
