CEM Problem
Old Nov 4, 2019 | 06:18 AM
Prettyboy357's Avatar
Default CEM Problem
Have a 2005 xc90 nothing electrical working inside the car runs an drive perfect
Old Nov 4, 2019 | 11:59 AM
Did you check fuses (both inside the cabin and under the hood)? The owners manual should show which fuses do what and where the boxes are (there's a few different locations). I'd also suggest looking at the relays to see if anything there is common to the issues
Old Apr 15, 2021 | 11:20 AM
Mike4393's Avatar
Default CEM information
Hello
Might be better to have your original part repaired at https://www.upfix.com
Here is the service link
https://www.upfix.com/product-catego...module-repair/
Old Apr 26, 2021 | 12:30 AM
Deeks's Avatar
There is a push switch in the ignition switch called S15 if that does not get depressed when the key is inserted it won't turn the power on for the CEM... first indication - no power windows. hit the end of the key with the palm of your hand and see if things come alive.
You can take off the column shrouds and remove the electrical part ot the switch and see the little button and give it a press as another test. At the same time you can look at the back of the column lock and make sure when the key gets inserted the the pin pushes towards
the ignition electrical switch.
JenniferXC70
2001-2013 model year XC70
Oct 25, 2022 10:46 PM
Alexis Covarrubias
Apr 21, 2019 11:41 AM
nyc1836
May 16, 2017 10:58 PM
Carlos Martinez
Aug 23, 2009 07:57 PM
