Control Arm bolt stuck
Old Aug 23, 2016 | 01:36 PM
gamador's Avatar
Angry Control Arm bolt stuck
Hello,
I am replacing the control arms on my xc90, I am having a hell of a time trying to remove one of the horizontal bolts on the control arm, the one on the left towards the rear of the car. There is very little space, I cannot fit the impact or any socket for that matter. I was able to get an offset wrench (12-point, could not get an offset 6-point) The bolt head started to get rounded at the corners so decided to stop and come here for help. I have seen other methods like, using a chisel, heat (last resource), etc. I have been using blaster spray, dw40, hitting it, etc. Any ideas would be really appreciated.
Thanks!
Old Aug 23, 2016 | 02:07 PM
Forget the WD40. PB Blaster is your friend.
Using a little heat to get it warn and soaking it with the blaster will help pull the blaster into the threads as it cools.
Old Aug 23, 2016 | 10:30 PM
schumicat's Avatar
are you using high quality tools? I have found that high end 12 point wrenches are much less likely to round off bolts than cheap ones. you can also try a crowfoot wrench (napa sells set - basically a wrench head that you use with a ratchet and extension). I have done this job but it has been a couple years and can't picture these bolts. maybe post photo? are these the bolts where there is a brake line or something limiting access?
Old Aug 26, 2016 | 07:20 AM
arfstrom's Avatar
I just did this on my car last weekend, I had similar problem with the brake caliper, driver side. hard to tell what car you have, (If you add your car to the signature,you wont have to tell everyone in every post)
I did see some post's were the engine may need to be pressed up with a 2x4, and a bottle jack, I was lucky I was able to use a extension to my ratchet (Lug-net wrench).
migbro
Sep 2, 2015 10:23 PM
Counselor828
Aug 22, 2011 12:19 PM
chef
Nov 27, 2009 08:57 AM
Platinum52
Jul 17, 2009 07:33 PM
rg500
Mar 31, 2009 01:25 PM
