cylinders rich cambers 1,2 & 3 no engine codes? please help!!
Old Oct 2, 2014 | 07:56 AM
christopherandrews1989's Avatar
Default cylinders rich cambers 1,2 & 3 no engine codes? please help!!
XC90 2.5T B5254T 2004 duel VVT
this is what ive done so far,
cylinder head rebuild - relapped valves, skimmed head, new valve stem seals, set valve tolerances
Replaced coils with IPD ones
New Bosch Spark Plugs
rebuilt exhaust system
new thermostat
new timing belt and tensioners
now here is my problem i have no engine light error codes - i removed the coil packs and spark plugs
and discovered that chambers 1,2 & 3 are Rich too much fuel and carbon build up in center of piston
chambers 4 & 5 are dry what i would like to know is what is causing this
when i did my cam alignments i set the cam locking tool and locked the cams in the horizontal position
in relation to the cylinder head then turned the VVT cams clockwise as far as they would go then
loosened the sprockets and using a piece of metal strapping aligned the timing markers with the timing
cover alignment marks the bolts in the sprockets were roughly in the center of the oval positioning holes
then set the crank pulley to TDC
now the only thing i wasn't sure of was the tensioner as i wasn't sure on this model if it was supposed
to be set in the 2 o'clock position or 7 o'clock position so i put it to 7 o'clock also on the VADIS program
it says when the cams are set up the exhaust should be advanced and the intake should be retarded
like a V-shape
but the locking tool only holds the cams on zero position???
here is something else - i had a misfire in cylinders 2 & 5 which turned out to be a blocked PCV system
which was solved when i replaced it now in the mean time i thought it might be the fuel rail so i got
a xc90 2006 fuel rail from the scrappy but what i didn't realize is that the injectors on the 04 are C rated
and the 2006 are A rated .. when i had this fuel rail on all my chambers were rich and now that i have
put the 04 rail back on only cylinders 1,2 & 3 are wet number 3 is the worst so IM suspecting three of the injectors
are leaking
i am at a loss as to what this could be and would really appreciate some help
thanks for your time
Chris Andrews
birdmayne
Feb 18, 2013 01:51 PM
WaltL
Feb 1, 2011 02:06 PM
volvoladys90
Oct 26, 2010 09:23 AM
MTNBKR
Aug 9, 2010 02:28 AM
huzzsaba
Apr 2, 2009 05:35 PM
