Dashboard lights came on, no reaction on gas-pedal
Old Nov 22, 2023 | 10:17 PM
PeterKok's Avatar
Default Dashboard lights came on, no reaction on gas-pedal
Started my car, was running ok. after a few minutes , abs lights came up, brake light came up, message with anti skid was disabled, than red light power issue. motor was still running but no reaction on gas pedal. Airbag light was on as well. Any suggestions before I bring it in. car has 250K on it. XC90 2008
Old Nov 27, 2023 | 02:44 PM
Jeshurun's Avatar
Default Likely failing or failed alternator
Sounds like a failing alternator. What's the charge status of your battery as well. You could get that checked out. For the alternator, take the negative terminal off while the car is running, and see if it continues to run.
Old Nov 27, 2023 | 04:08 PM
If that is done to a modern car and the alternator is charging - a voltage spike could occur and damage something expensive. The battery acts as a capacitor absorbing spikes. That was a somewhat valid test years ago - particularly when cars had generators and no electronics to fry.
Old Nov 27, 2023 | 11:56 PM
Jeshurun's Avatar
I agree with your statement that the test may not be suitable for more electronically-composed cars today. My recommendation though, was in the context of the OP's P2 XC90.
Old Nov 28, 2023 | 08:00 AM
A 2008 xc90 has 20 or so modules (computers) CAN, LIN and Most networked together. Even the alternator is on a LIN network.
I would not want to accidentally induce a voltage spike in any Volvo after about 1998. And would not intentionally disconnect a battery on Any car running with an alternator.
But - your mileage may vary.
Old Nov 28, 2023 | 08:03 AM
Jeshurun's Avatar
[QUOTE=hoonk;528525]
/QUOTE]
Fair enough. Pleased to make your acquaintance. Cheers 🤝🏾
Old Nov 29, 2023 | 05:43 PM
PeterKok's Avatar
Started the next day and everything seems normal. Very weird. So far no issues. No codes showed up on my reader.
Will keep a close eye on it.
Thanks for the reaction.
cyrusyn
Mar 19, 2013 06:48 AM
mountain lion
Apr 26, 2011 03:37 PM
chrystald423
Mar 27, 2010 08:05 AM
BlackXC9009
Feb 25, 2009 12:50 PM
Psaboic
Jun 1, 2006 01:14 AM
