DIM vs. CEM
Old Jul 18, 2015 | 08:40 AM
allenot1's Avatar
Default DIM vs. CEM
Is there a test to definitely find out if it's the DIM or the CEM is faulty? I want to make sure I'm sending Xemodex the right part to fix. Thanks!
Old Jul 18, 2015 | 09:08 AM
ES6T's Avatar
Not really. Unless you have VIDA and even then it isn't always easy.
What are your symptoms?
Old Jul 18, 2015 | 09:48 AM
allenot1's Avatar
So, I'm driving and all of a sudden the red triangle lights up with the brake ABS FAILURE warning light. Then turn signal is intermittent. Windows and radio stopped working. After that, the entire DIM SHUTS off, no tach, no lights. But the car drives fine. Pull over and turn the car off, wait for a click then turn it on. Everything works fine. It hasn't happened since two weeks ago. The outside temp was 102 degrees.
JenniferXC70
2001-2013 model year XC70
Oct 25, 2022 10:46 PM
borrone821
Nov 26, 2007 07:27 AM
veso_ht
Mar 3, 2007 12:22 AM
jay philoon
Jan 23, 2007 12:09 AM
s_vanvooren
Oct 19, 2005 02:17 AM
