Fuel System issues
Old Aug 4, 2016 | 10:40 AM
leuelliot's Avatar
Unhappy Fuel System issues
My 2007 xc90 3.2 threw this code p0087 (fuel rail/system pressure too low) two days ago, i pulled over and clear it, checked fuel pressure via OBD2 it read 458kpa at idle, yesterday it threw the same code, when i got home i replaced the fuel filter, fuel pressure now reads 438kpa at idle. i noticed it now throws this code immediately i start driving. It runs great it doesn't misfire or stall or have any other codes besides 0087 for now.
(3 weeks ago i cleaned and cut a small hole on the screen attached to the fuel pump because it was getting blocked every 5 months) could this be a cause?
I'm thinking faulty FPS or Failing fuel pump.... any help would be appreciated
Old Aug 4, 2016 | 04:23 PM
leuelliot's Avatar
it's also noteworthy; that the code doesn't pop up no matter how long it idles after a start. But once i start moving it comes up, if i clear it while the engine is running it doesn't re occur until the car is restarted. and it became this frequent after the fuel filter change yesterday.
Old Aug 4, 2016 | 05:01 PM
Smith Volvo's Avatar
Banned
sounds line your fuel pressure sensor (very common)
in stock
31272732 PRESSURE SENSOR $77.89
OVERNIGHT FEDEX $13.00
File Type: pdf
Old Aug 5, 2016 | 02:58 AM
leuelliot's Avatar
in stock
Thank you sir! i don't live in the states, so I'd try sourcing for it locally first. Thank you.
xDread92x
May 7, 2014 08:37 AM
Annee.g
Oct 10, 2011 01:00 AM
RGV10
Sep 8, 2011 07:26 AM
sleepy_dread
Jul 25, 2011 05:20 PM
