Hello got a 2006 XC90 V8 trouble code 0193
Old Sep 16, 2012 | 11:13 AM
chermecz's Avatar
Lightbulb Hello got a 2006 XC90 V8 trouble code 0193
New within the year to Volvo ownership...Love this SUV...I have an OBD2 code reader...I guess these vehicles have major "techy" systems and need special tools to do alot of the work...correct me if I am wrong..I have a check engine light on..Car started acting crazy a couple days after light came on..Symptoms: stalling, misfiring, chugging..I found out that my daughter put a full tank of 87 octane in the tank...could this maybe have started the fuel pressure sensor issue? I had a mechanic change the fuel filter..light is still coming on within 1 driving cycle...It was intermittent at first..Before the full tank of 87..Now comes on and stays on... Can I bleed the fuel system pressure by taking out the fuel pump fuse and letting the engine run out of gas? If so then is this part change out straight forward? How can I bleed the system properly without a special connector and pump..
Thanks Chris
Old Sep 19, 2012 | 10:34 AM
schumicat's Avatar
check the manual but I suspect it will recommend 87 octane and the octane rating has nothing to do with this. higher octane in cars that don't need it (e.g., higher compression ratios) is a waste of money. the sensor may be bad or your fuel pump may be weak/failing. the fuel injection will usually hold some pressure and you can expect some gas to spray when you open they system.
Scuba Jim
North East
May 26, 2024 11:29 AM
chermecz
Sep 16, 2012 11:09 AM
kapka42
Dec 21, 2009 09:47 PM
zral
Sep 27, 2009 01:48 AM
miguelito22
Apr 12, 2008 08:57 AM
