Help with air filter replacement
Old Mar 24, 2008 | 12:07 PM
hsstadler's Avatar
Default Help with air filter replacement
Hi I have a 2006 XC90 5 cylinder turbo.
It has about 30K on it and I wanted to change the air filter. I ordered a replacement from IPD. The air filter housing has three metal spring clips that I unsnapped to access the old filter. I disconneced an electronic connector going into the top of the air filter housing and unsnapped the three clips. I pulled the old filter which had leaves and lots of black soot on it. I cleaned out the air filter box and put in the new IPD filter which looked very close to the OEM but did not have Volvo on it. The problem is that I could not get the top of the air filter housing unit on correctly. There seems to be 3 plastic bars on the top housing piece that needs to slip into three slots on the back of the bottom part of the housing. I loosened the hose clamp connecting the top of the air filter housing and that allowed some pivot, but I could not angle the housing to go in correctly. I also could not disconnect the housing from the long black pipe as there seems to be 2 torx like screws with a metal post inside of the star pattern that required a special wrench. I even tried putting the original volvo fiter back in an I still could not get the top housing in correctly, so I do not think that it is an incompatability wiht he IPD filter. Any suggestions would be great.
Scott
Old Mar 24, 2008 | 12:50 PM
luvmyXC90's Avatar
Default RE: Help with air filter replacement
I just replaced my filter and it was hard to get the housing back together and I did have a volvo filter. What I had to do was get the top angled so that the three bars are ready to slide into the slots then pushdown on the filter like you were going to snap the metal clips shut but with a flat tipped screw driver push down on the bars so that they slide into the slots. That was all I had to do and then it went together fine.
hope it helps a little.
K.
debargha
Feb 24, 2015 10:46 PM
bluemagicbus
May 17, 2011 07:18 AM
S40 Wheelman
Jan 12, 2011 07:09 PM
edahlgren
Oct 21, 2010 06:24 PM
Ahmed
Mar 28, 2008 04:22 PM
