HID upgrade possible despite DRL?
Old Oct 1, 2008 | 02:24 PM
MIK911's Avatar
Default HID upgrade possible despite DRL?
I own a 2006 XC90 withOUT factory Xenon/HID. I want to replace the halogen low beam headlight with an aftermarket HID kit (bulbs, ballasts,etc). BUT the low beam is currently used for DRL, so is "ON" all the time.
Anyway to add aftermarket HID with this scenario?
thanks
Old Oct 1, 2008 | 03:10 PM
Default RE: HID upgrade possible despite DRL?
I have the Hid's in my 850 and the DRL are on all the time.
If you really wanted to you can go to the Dealer and have them disable them. But it will cost you.
Old Oct 2, 2008 | 12:01 AM
MIK911's Avatar
Are your HID's aftermarket? So did you just replace the factory halogen low beam with a HID kit?
Any false triggering of warning light on dash?
I have no desire to delete my DRL function, and wouldn't mind if the DRL's are HID.
I was under the assumption that the Volvo low beamDRL function at a lowervoltage than when the usual low beam headlights are"ON" at night (that's the way it is on BMW's highbeam is DRL but at reduced voltage). If this is true, I was afraid of triggering dash warning light due to lower voltage draw.
Perhaps I am wrong.
Also, In a recent 'search', I read that to prevent triggering warning light on dash, that a 55Watt (not 35W) HID kit needs to to be used. Is this true?
Thanks
Old Oct 2, 2008 | 07:45 AM
Yes mine are aftermarket.
It might trigger a false bulb out light but if you look at this link they found a way around it.
http://www.xenonvalot.com/xenonfixvolvo.html
I believe but may be wrong but the only ones that are like you described are the ones with factory HID's. The HID's shut off during the day.
Not sure about the 35 watt kit.
Old Oct 2, 2008 | 05:54 PM
MIK911's Avatar
Great info.
Thanks, tech
RJSV70
2001-2013 model year V70
15
Oct 26, 2013 06:05 AM
2005s60
Jan 19, 2011 01:50 PM
MIK911
Jan 6, 2009 04:41 PM
raymondo
Dec 2, 2005 08:45 PM
