High Beam Failure
Old Nov 3, 2006 | 10:39 AM
pbrengel's Avatar
Default High Beam Failure
I have a 04 XC90 and can't get the high beams to work. The blue
indicator on the dash is on and high beam L & R fuses appear to be ok
but no high beams. Any suggestions. Many thanks. Phil
Old Nov 3, 2006 | 10:02 PM
Default RE: High Beam Failure
Do they flash when you pull on the switch?
Old Nov 6, 2006 | 12:58 AM
m1964's Avatar
ORIGINAL: tech
I think he figured it out..
Old Nov 6, 2006 | 09:24 PM
pbrengel's Avatar
no.
Old Nov 6, 2006 | 09:29 PM
pbrengel's Avatar
no flash when switch is pulled. Also checked the cabin high beam fuse and bulbs. Looked ok.
Old Aug 17, 2008 | 12:09 PM
mudder55372's Avatar
I have the same problem. bulb and fuses are fine. High beam on - on the dash. low beams rotate.......still no high beams. Fuse box has power. Is this a relay problem?
Please advise on how to fix.
Old Feb 5, 2011 | 11:48 AM
johnmitchell's Avatar
this looks like an old thread but i have the same problem with my 2006 xc90. Any ideas
Old Feb 18, 2011 | 07:20 PM
04t6xc90's Avatar
I have a similar question. When I switch the high beams on, I see a flash, but on normal cars, the regular beams are outer, high beams are inner. We bought the car used but I think it has the Xenons...basically if I do NOT put the headlights on, and it is dark, they are on and so are interior lights. So the only way I've known I didn't have my headlights "on" was because I"d go to switch to high and nothing would happen.
Back to my question. I flick the high beams. THey flash, it seems like they are aiming higher, but seriously NO ONE high beams me and I feel like my field of vision isn't as big as I'd like it to be. Should I see additional lights come on, or are the high beams the same as the low beams and they are just aimed in a different direction? So confused. Please help.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
jasonthaynes
Dec 2, 2012 05:32 PM
Volvoguy505
Sep 11, 2010 05:53 PM
V50T5
Mar 19, 2006 04:35 PM
sfyffe
Mar 23, 2005 01:37 PM
