ignition key removal
Old Feb 22, 2009 | 09:35 PM
cleach's Avatar
Angry ignition key removal
2004 XC-90 with about 68,000 miles. It is getting more and more difficult to remove the ignition key. This started a few weeks ago. Is this a common Volve problem, and does anyone have any ideas about a fix without going to a dealer?
Old Feb 23, 2009 | 09:05 PM
Try spraying a little bit of WD-40 in there and see if it helps.
Old Feb 23, 2009 | 09:40 PM
Sailing_Faith's Avatar
My V70 sometimes does not want to release the key.
It appears to be related to the gear shifter, it does not want to let the key go in any position other then park. If the button does not pop out all the way, I have to push it in a little and let it come back out before the key will slide out easily.
Hope this helps.
dodgerkcj
Jul 2, 2018 11:41 AM
Ricardito
Aug 14, 2012 08:29 PM
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
