Installing axle - problems
So, installing a passenger side axle in a 2006 XC90. the outside end of the axle shaft that goes through the wheel hub...the spine coming out has two problems:
1) it doesn’t come out all the way; it should come out another 3/4" or so.
2) the axle bolt only partially screws in. It is about 1/2" from the hub.
So, even if I can fix #1, the bolt would still be ~1 1/4" sticking out.
Anyone have any ideas?
Unfortunately, that is not possible. I removed this same axle to do an alternator replacement (Grr...) so I don’t have anything to compare it to. Yet, I do know that it fit when I took it out.
Any other thoughts/ideas?
