Passenger Side CV Axle popping out of XC90 V8
Old Aug 25, 2016 | 12:38 AM
L76's Avatar
L76
Default Passenger Side CV Axle popping out of XC90 V8
Replaced front wheel hubs, control arms, struts, ball joints, etc. recently and put car back together. Everything fine for about 60 miles...then axle started to back out of the transmission. Got the car home (it finally seized up and wouldn't move, so had it towed) and everything *appears* fine now that axle is out of the car.
Can't figure out why the axle would come out in the first place??? Some considerations:
1. This is an after market axle. There is no circlip that holds the axle into the transmission. (I called a friend at a Volvo dismantler who looked at over 20 axles he had... None had circlips)
2. This axle ran fine in the car for 100k+ miles. There appears to be nothing wrong with it now. All splines look good, bearing is fine, etc.
3. I looked into transmission tunnel (where axle installs) and could not detect/see any clip... The "axle tunnel" looks clean
Any thoughts? What holds the axle into the transmission anyway? Any installation tips? I don't know what to do other than put it back together and pray.
Thx for your thoughts/suggestions...
Dennis
Old Aug 25, 2016 | 05:13 AM
ES6T's Avatar
Which side?
Old Aug 25, 2016 | 07:42 AM
L76's Avatar
L76
Default Passenger side
Passenger side.
Old Aug 25, 2016 | 09:49 AM
ES6T's Avatar
Do you have the bearing retainer installed?
Old Aug 25, 2016 | 09:12 PM
L76's Avatar
L76
Default Not axle popping out... actually bad cv joint
So... further inspection analysis... the CV joint itself went bad. Replaced the axle today... but I cannot get the very last nut on!!! Doh! ... I cannot get the lower ball joint on after 90 mins. Uhhh. What is right sequence for rei-nstallation of axle? Here's what I did:
1. Insert axle into transmission
2. re-attach the cap that holds the axle bearing to the block
3. Insert axle into wheel hub
4. lock the axle down to the hub (tighten bolt that holds axle to hub)
This leaves the lower A arm kind-a hanging down... attached to the frame but not to the lower ball joint. The wheel assembly has the full struts, tie rod ends, steering, etc. still attached... but for the life of me... I CAN NOT get the lower ball joint on. Any ideas on how to get this done? Did I install in wrong sequence? Do I need to unbolt the lower A-Arm (already tried this and got nowhere)?
cheers,
Dennis
Old Aug 25, 2016 | 09:16 PM
ES6T's Avatar
Volvo makes a special tool that is a huge c-clamp that compresses the spring to get it back together. Without it, you can try a huge pry bar, or unbolt the spindle from the strut (remove the axle bolt first), put the ball joint in, then put the spindle back in the strut.
brorat77
Sep 9, 2019 02:17 PM
Markvolvo
Dec 29, 2013 01:23 PM
bizzy102
Mar 29, 2012 11:31 AM
ctullar
Nov 20, 2010 04:27 PM
ccpr20
Jan 4, 2009 09:25 AM
