Loud screeching near pulley area
Old May 26, 2014 | 02:16 PM
tpc1210's Avatar
Default Loud screeching near pulley area
2008 XC90 3.2 FWD. The sound stops when I pull oil dipstick. Was told to clean or replace crankcase box under intake manifold, but no other directions given. Only thing I see below are the alternator and oil filter housing. Any advice would be appreciated. Thanks in advance
Old May 26, 2014 | 06:50 PM
damien360's Avatar
There is no pcv box under the intake manifold on these engines. Either you read the engine type wrong or someone gave you the wring information. Either way you will need to replace the pcv box that is located on top of the engine. It will be the black box on the back of the engine under the engine cover. All you are going to need is a T30 and ratchet with a small extension to replace the oil trap box.
Old May 27, 2014 | 08:21 AM
tpc1210's Avatar
Thanks Damien. I did take that box off yesterday and tried cleaning it but still had the loud whistle. I will replace and see if that helps. Thanks again for quick response.
Old May 27, 2014 | 02:03 PM
tpc1210's Avatar
Replaced oil trap($197.00/20 minutes) and all is well. Thanks Damien
TheVolvoMan
Apr 14, 2015 05:24 PM
Darmich0712
Apr 17, 2014 06:44 PM
LOVEvolvos
Apr 24, 2012 10:36 PM
guest01
Nov 5, 2011 10:11 PM
