Low voltage problem
Old Jan 19, 2018 | 04:41 AM
EOW's Avatar
EOW
Default Low voltage problem
Hello All...
Any suggestions will be appreciated, I have a petrol '04 XC90 and recently it has starting showing low voltage (11.77v) at the main terminals under the bonnet, this has effected the lpg system which now beeps as if empty every time the ignition is switched.
While at an lpg installer the other day the 2 year old battery was tested by auto electrician and found to be fine and charging ok, an extra battery was also connected to it but still only read 11.82v under the bonnet...!!
Any ideas what to check next ??
Thanks in advance
Craig
Old Jan 19, 2018 | 06:48 PM
did you measure at the alternator or just the battery?
catlurver
Apr 28, 2013 04:28 PM
Meateater
Jul 8, 2011 11:12 PM
Srogers
Sep 3, 2009 05:15 PM
volvo40_2k
Jul 28, 2009 09:18 PM
gordon368
Jan 29, 2006 09:56 PM
