(P0366 & P0040) 2004 XC90 T6 2.9l
Old Aug 11, 2015 | 09:01 PM
christopherandrews1989's Avatar
Default (P0366 & P0040) 2004 XC90 T6 2.9l
hello everyone need help as my xc90 will crank but not start 99% of the time
here are the following codes
(P0336) - Crankshaft Position Sensor A Circuit Range/ Performance
(P0040) - O2 Sensor Signals Swapped Bank 1 Sensor 1/Bank 2 Sensor 1
i have replaced the following
1.timing was off i have corrected this using the correct locking tools and VADIS
2.fuel pump was leaking - replaced along with filter
3.coil packs have been replaced along with spark plugs
4.replaced the crank position sensor and cradle
5.replaced the starter motor just for the hell of it
i have had the car running 3 times but this only occurs rarely and once i turn it off it wont start again
i have herd it could be 1 of 3 things
fly wheel, starter motor emp messing the crank position sensor signal or
gearbox has not got the correct earthing to chassis or bell housing to engine
i checked the 3 grounding points on both sides of the fenders and sanded the contacts
please help me as im starting to get that hopeless feeling
thanks for your time
Chris
Politikz
Sep 29, 2014 04:32 PM
1jacs xc90
Apr 29, 2013 08:32 AM
Josiah Poupard
Jun 1, 2011 08:10 PM
garydrenk
Sep 18, 2010 12:02 PM
huzzsaba
Apr 2, 2009 05:35 PM
