passenger side water leak
I have being going crazy trying to find the source of water that has been pooling at the foot of the passenger side.
I have tried:
-sunroom drain
-ac drain
-swearing at it
-seal below window, on top of air vents (it looked like this was the cause, as the water was kind of pooling. I though it might be spilling over before it got to the real drain... so I sealed the intake with calking)
-swearing at it again
-countless other things
I have the glove box out, and it seems like it is coming from behind where the glove box was. I can't trace the leak up at all though. Very frustrating.
I have googled a lot of other threads on similar issues, but haven't found anything that looks like a likely cause.
Anyone have other suggestions?
I have tried:
-sunroom drain
-ac drain
-swearing at it
Did you check to see if the sun roof drain tubing is still connected together? Mid way between the floor and roof the tube is connected together. I forget the exact location but I think it was behind the pillar cover. Mine had separated and I ended up with water on the passenger side.
Qamar
11-14-2005 12:53 AM
