View Poll Results: Thoughts about the fix?
Did it work for you?
0%
Do you have a better solution?
0%
Problems or issues?
0%
Something else?
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Permanent drain tube fix - cheap
Old Jul 5, 2021 | 11:20 PM
FrankGuthrie's Avatar
Default Permanent drain tube fix - cheap
Volvo roof drain permanent fix.
Order the item below.
Remove pillar cover - remove stupid rubber drain tip (water may be trapped in drain tube - clean out tube in some way).
Install the silicone item - it's a perfect fit on drain tube and drain hole where rubber tip was. Replace pillar cover - done.
Never again - and a fraction of the cost of the original piece.
https://www.aliexpress.com/item/4000...e52e080e3518-9
There are plenty of other sources - prices vary quite a bit.
Racoon-wa
Jul 26, 2014 06:15 PM
akabond
Jan 13, 2014 12:52 AM
xc902006
Jul 3, 2009 08:01 AM
nomadly
Apr 9, 2008 05:37 PM
colgate41
Oct 14, 2005 10:23 PM
