trouble codes
Old Sep 2, 2008 | 10:19 PM
ROBLU540's Avatar
Default trouble codes
Hi, I own a 96 850 turbo.
I have two codes, P0103 and P0172. I'll go back a few months,the vehicle started shaking severely when stopped at a light especially when the AC was on. If I turned the AC off it would stop. But when I drove at a constant speed it was fine. I replaced the PCV system hoping it would fix the problem. The PCV system was blocked. The check engine codes went away.
Fast forward, the codes returned a week later and the intermittent shaking. What could this be. I dont think the MAF sensor would make the vehicle shake. or am I wrong.
Your help appreciated.
Old Sep 3, 2008 | 07:28 PM
Default RE: trouble codes
Either you have a huge vacuum leak or a bad MAF.
Old Sep 3, 2008 | 08:54 PM
ROBLU540's Avatar
how do I check if I have a huge leak.
Old Sep 3, 2008 | 09:19 PM
A really big one you should hear. A smaller one you can spray Carb cleaner around all hoses and intake manifold. If the idle changes you found the leak.
Old Sep 4, 2008 | 08:24 AM
Psaboic's Avatar
I would definitely check all the vacuum hose connections at the vacuum hose "tree" by the distributor.
Old Sep 4, 2008 | 08:08 PM
ROBLU540's Avatar
so today I ordered a new MAF, hopefully this will fix the problem.
Old Sep 4, 2008 | 08:41 PM
I hope so as well. If you have no leaks at all that is the last thing it could be.
Old Sep 10, 2008 | 11:53 PM
ROBLU540's Avatar
Got my MAF sensor today and installed it, went to Autozone and cleared my Check engine light. So far so good.
Old Sep 11, 2008 | 03:24 PM
ROBLU540's Avatar
Spoke to soon,
My check engine light came back, now I just have a P0172 code. Fuel system too rich for bank 1. Is this a Oxygen Sensor issue? On the bright side, the vehicle does not shake any more, and seems to be running better.
Old Sep 11, 2008 | 06:37 PM
It may be the O2 sensor now.
B1mmer
Dec 18, 2006 11:24 PM
mrscullini
Nov 24, 2006 03:28 PM
mrscullini
Nov 11, 2006 05:30 PM
TBoone
Aug 8, 2006 12:52 AM
katrina
Feb 11, 2006 04:56 PM
