Question on Brakes/rotors
Old Jul 24, 2011 | 07:12 PM
redvv07's Avatar
Default Question on Brakes/rotors
Hello,
I have an 07 XC90 6cyl, I recently had my front brake and rotors replaced after I had grinding and turning issues. I went to my local "chain" mechanic, all total cost was 672.00.
My question is, are the parts cheaper somewhere online I can buy and take to them the next time or is it always this expensive?
Also if anyone recommends a good parts site, what is a good brand to use or look for?
I bought my car used and this is its first replacement. (first of many I'm sure)
Old Jul 24, 2011 | 07:28 PM
bmoore's Avatar
If you would have watched them do your front brakes, you probably would have been angry. Front brakes, especially when you are just removing and replacing pads/rotors, is an extremely easy operation. Parts cost with name-brand parts is about $150-200 total. If it's your first time, it could take you a couple hours. After doing many dozens of pad/rotor jobs, I can do both sides in about 20-30 minutes.
It's that easy.
Edit: rockauto.com is a good place to find parts. A good set of pads/rotors for your car can be had for about $100, complete.
Old Jul 24, 2011 | 08:26 PM
redvv07's Avatar
Thanks bmoore!
Just did a quote on Rock Auto, under 200 dollars!!!
Will most definately go that route next time!!!
Old Jul 25, 2011 | 06:30 AM
Volvos rock's Avatar
Just did our XC70 a few months ago, Brembo rotors, Akabeno pads, new lines =$210.00 at FCPgroton.com. They are extremely easy, if your even remotely mechanically inclined. Ill do em for $400....
Old Jul 27, 2011 | 03:26 PM
itsabowtime2's Avatar
Brakes, especially Disc are not difficult to replace. Depending upon how expensive you want to go replacement pads can be had for less than $40.
I still do my own brakes. Finding someone to do them at a fair price is difficult to do.
If you do not have one already, get a shop manual. You will be amazed at how quickly you can become a DIY.
Old Jul 27, 2011 | 04:17 PM
Ovlov Lacidar's Avatar
I never even bother replacing the rotors or having them turned (refinished), I just drop new pads in there. Pads are cheap and easy to replace, so what if not turning the rotors means I have to drop in new pads 2,000 miles sooner.
My $0.02 anyway, I'm sure professional mechanics and ****-retentive safety police will tell me I'm risking my life...please. It's a metal disc clamped between two abrasive pads, not rocket science.
Old Jul 30, 2011 | 07:42 AM
bmoore's Avatar
That's fine, to a point. But I hope you're aware that rotors wear, too. Don't end up like this:
Old Aug 1, 2011 | 11:32 AM
Lol, looks like that guy had caliper pistons sticking on the one side, the other side of the rotor is fine.
I do eyeball the rotor wall thickness at the vents and look for a ridge at the minor ID of the pad swept surface, if there's ever any clearly visible wear I'll replace the rotors. So far so good, but I drive like an old lady.
adamsrotors
39
Jun 25, 2015 01:01 PM
adamsrotors
49
Jun 25, 2015 12:58 PM
topkat418
Nov 17, 2013 12:59 PM
Gusto
May 3, 2006 12:06 AM
JC
Sep 20, 2005 08:51 PM
