Rear Entertainment System AUX specifications
Old May 7, 2016 | 05:00 PM
fooman's Avatar
Default Rear Entertainment System AUX specifications
I am trying to get the AUX (composite) in for my 2011 US model RSE system to work. Its the factory-installed system with two non-tiltable screens and one DVD player mounted in the middle console.
The DVD works fine. But when I connect a source to the auxiliary in via composite, I get a partly visible, partly garbled picture that is black&white most of the time, and sometimes has a bit of colour in it. I tried with two different input sources (a raspberry pi and a sony camcorder). The result is the same.
I suspect this is an issue with the signal standard (PAL, NTSC, Progressive, Interlaced) and/or the resolution. I tried several combinations but nothing seems wo work.
Does anyone have the specs of that screen, or did get AUX input to work?
Thanks,
Toby
ALIAS223
Sep 1, 2018 04:41 PM
marveryl
May 29, 2013 03:15 AM
daotan
Jul 15, 2012 09:36 AM
Bosshoff
Oct 6, 2011 01:51 AM
atornquist
Mar 24, 2008 11:36 AM
