Rear wheel bearings info request
Old Oct 29, 2008 | 08:41 PM
bigtombbq's Avatar
Default Rear wheel bearings info request
I have read through the previous posts about the rear wheel bearing problems. Most are from AWD owners, mine is an FWD model.
I have also looked through several parts sites for additional information and associated parts/special tools etc required for the rear wheel bearing assembly replacement. From the postings the actual replacement may not be that difficult a task.
Are there any more details that can be shared? ie: special lubricants, torque specs, sealants or thread lockers, etc.
Thanks.
As a secondary issue, where can I find a repair manual for the '04 XC90? I have not found any online resources for that item yet.
Old Nov 7, 2008 | 11:37 PM
JPN's Avatar
JPN
Default RE: Rear wheel bearings info request
Since I am an 850 driver, I am unable to answer your questions. However, have the recalls done at the dealer (free of charge) if not done yet:
http://www.autobuyguide.com/2004/12-...lls/index.html
Newer Volvo seems to use electronic service manuals only (VADIS/VIDA), and at the moment no one (Haynes, Chilton, etc...) seems to have been publishing manuals for newer Volvos. Not sure why.
The XC90 forum seems slow, so in case if you did not receive any reply within a day or two, try posting threads in General Volvo Chat.
I hope this gets you started. Wish you luck.
JPN
Old Dec 1, 2008 | 03:29 PM
bigtombbq's Avatar
New bearing units installed on both rears this weekend. No problems only took a few hours each side.
orb
Aug 19, 2015 08:31 AM
wwilme
Sep 19, 2013 10:32 PM
CPVolvo
Dec 22, 2011 03:49 PM
OGee
Jul 1, 2011 01:57 PM
dutch connection
Feb 13, 2010 08:39 PM
