rear wiper not working
Old Jul 26, 2014 | 05:55 PM
Racoon-wa's Avatar
Default rear wiper not working
I was able to get my rear window wiper to work after being out for awhile. With the key on and the wiper switch on continuous, I gently nudged the wiper arm to the right, and quickly the motor started working perfectly.
The dealer electrical trace in my case pointed to the wiper motor. The dealer fix is to replace the motor for about $600, of which the part is $300. I came up with the idea of moving the motor to unfreeze it.
Old Jul 26, 2014 | 07:17 PM
damien360's Avatar
If the motor failed once more than likely it will fail again
Old Aug 15, 2014 | 02:29 PM
cn90's Avatar
REAR Wiper Motor PN is 8638163, about $250.
Very easy to DIY.
Old Aug 15, 2014 | 02:33 PM
cn90's Avatar
Information for rebuild is in the links below. Basically remove the shaft, clean it and re-lube it.
No cost other than your labor.
Volvo XC90 Rear Wiper Motor Tip - Hot Rod Forum : Hotrodders Bulletin Board
http://www.volvoforums.org.uk/showthread.php?t=141314
Picked it up Saturday, was driving home yesterday in the rain admiring the rain-sensing wipers when we noticed the rear wiper motor was operating erratically. Did some research and discovered they have a current cut-off switch that senses when the motor is overloaded. The circuit will open upon an over-current condition, then close every few seconds in an attempt to clear the obstruction and at least store the blade, so it would move a little then stop... repeatedly.
Parts store wanted $150 for a rebuilt motor, stealership wanted $300 for a new one. Decided to tear into it and, after completely disassembling the brush motor and gear system I determined that the shaft connecting the wiper arm to the gear system was locked up. *Gently* removed the shaft with a punch and hammer and found the two bushings full of rust. There is an o-ring on the outer portion of the shaft which is supposed to prevent water from making its way into the shaft tube, but inevitably it gets in there. Cleaned up the bushings with some PBlaster and wire brush, cleaned up the shaft, applied anti-seize to the bushings and reassembled. Worked like a charm! We now have an operational rear wiper, and saved several hundred dollars. Figured this might be helpful for you Volvo owners out there, and it sounds like this is very common with their rear wiper motors.
Old Mar 1, 2017 | 10:22 PM
Racoon-wa's Avatar
Update - Since the original post, the motor did cease periodically, but I could get it going by rotating the wiper. However, I replaced the battery and presto, the wiper perked right up and has been working perfectly and starting the engine is much better. Volvo tech said that the battery was weak and under delivering voltage.
At 150,000 the XC90 is running great. Thanks to Volvo in Tacoma.
Old Jun 10, 2018 | 05:31 AM
Thorjürgen's Avatar
Helpful, thanks ������
Old Jun 10, 2018 | 05:32 AM
Thorjürgen's Avatar
Thanks so much for taking the time ������
richardgrant
Apr 28, 2015 08:22 PM
rspi
May 15, 2014 07:36 AM
BigAdam
Oct 21, 2008 10:01 AM
