Replacement XC 90 front brake rotors
Old Jul 29, 2011 | 06:04 PM
dan578's Avatar
Default Replacement XC 90 front brake rotors
I am planning on replacing the front brake rotors on my 2009 FWD XC90 with 3.2 L motor. Upon checking several sources for OEM rotors, I find rotors with three different diameters listed for my car. These are: 316mm, 328mm and 336mm. How do I determine which is the right size without removing the wheel from the car and measuring the rotor diameter?????
Any help would be greatly appreciated.
dan28
Old Jan 4, 2014 | 01:32 PM
REG44's Avatar
Hello Dan578. Did you get a reply to the rotor size question? I have a 2009 Volvo XC90 with 18 inch tires but need to know my rotor size also. Any update is appreciated!
Old Jan 5, 2014 | 11:29 AM
vinny's Avatar
When I replaced pads for the first time even the dealer did not know so you will have to measure. I bought both and returned the others. Second brake job on spec at 150k kms I knew they were 336 mm and also replaced the rotors.
Old Jan 5, 2014 | 11:32 AM
vinny's Avatar
Mine is 7 passenger, maybe that makes a difference.
Old Jan 5, 2014 | 01:17 PM
damien360's Avatar
You can always call he dealer and see if they can give you he correct information all they need is the VIN and they can see the vehicle details in VIDA
Old Jan 9, 2014 | 02:37 PM
Blownby's Avatar
If any of you have a question as to which brake system your XC90 has,Post your VIN of the vehicle in question and Ill post which brake system it has on it.
Old Jan 11, 2014 | 09:23 AM
REG44's Avatar
Smile Rotors for 2009 XC90
Got my rotors. I hope they are a the right size. I think they are 336mm.
Thanks for the assistance on this matter!
adamsrotors
39
Jun 25, 2015 01:01 PM
adamsrotors
49
Jun 25, 2015 12:58 PM
mrvolvos60
Sep 11, 2014 07:39 PM
eldee50
Sep 18, 2007 08:21 AM
giacomozzi
Feb 14, 2006 10:22 PM
