Second and Third Row Map Lights not working
Old Jun 12, 2018 | 09:11 PM
jorosal's Avatar
Default Second and Third Row Map Lights not working
2016 xc90 with an interior light problem. Cannot figure this out. The map lights in the front part of the cabin and all other courtesy lights work fine. The map lights over the second and third row do not come on. No matter what I try. The lights on the tailback and rear work as well. Any ideas?
Some additional information:
I had not realized that the sunvisor lights also were not working. I tracked down the fuse responsible for these lights - #28 in the passenger compartment. However, the fuse will blow immediately upon replacement.
Old Sep 22, 2019 | 05:33 AM
Nikhon's Avatar
Hi Jorosal, did you ever find the cause of this issue? Same this is happening for my 2016 XC90
Any help would be appreciated, I've tried like 5 fuses and they all blow instantly on replacement.
Old Jan 23, 2022 | 12:12 PM
RHJinVA's Avatar
Same here. 100K mi, and like all good Volvos, this one has been passed along to my college student, so there is not much urgency nor a great deal of budget to apply toward this problem. But it would be nice to get it fixed.
Old Dec 30, 2022 | 03:33 PM
mcu's Avatar
mcu
Anyone ever figure this out? Having same issue on my 2018 XC90. Keeps blowing fuse 28, so there seems to be a short somewhere and not sure how to find the issue
Old Jan 26, 2025 | 11:49 AM
Carlosgp03's Avatar
Any solutions to this?
Old Jan 29, 2025 | 02:05 PM
you'll need to check a wiring diagram to see what's on that circuit then check junctions to see where the power is shorted to ground. You can also try pulling out all the bulbs etc to see if the fuse stays intact.
Hudini
Mar 30, 2020 06:06 PM
arturo3002
Feb 15, 2018 07:13 PM
jittest1
Nov 12, 2008 10:53 AM
merlin
Sep 11, 2005 06:22 PM
ojala
Jul 2, 2005 11:37 AM
