Throttle body Issue - wiring diagram 07 xc90 3.2
Old Sep 1, 2023 | 08:07 PM
vmaxmike's Avatar
Default Throttle body Issue - wiring diagram 07 xc90 3.2
Hi,
anyone have access to wiring diagram for the throttle body? I removed the intake assembly to do an alternator job and after putting back everything, car runs bad, has reduced performance message and the throttle body seems to not be functioning correctly. Triple checked all connections. Scanner shows fault codes P2106 and P1589. When I try the scanner active test to open the valve (25% 50% etc ), nothing happens, it just buzzes. With key on, I probe the connecter and only get 5v at one of the six prongs. Shouldn't I get 12? Not sure if I got a bad TB that was working fine prior to removal or low voltage going to it causing it not to operate...
Old Sep 2, 2023 | 09:52 AM
You can find a wiring diagram here
https://volvodiag.com/ewd-online-eng/
Old Sep 2, 2023 | 09:01 PM
vmaxmike's Avatar
Thanks!
turbotim23
Mar 23, 2023 09:00 AM
Feversm
May 24, 2022 04:12 PM
Vanni
Apr 26, 2022 11:22 AM
Psaboic
Nov 4, 2009 08:37 PM
byinternational
Jul 3, 2009 08:32 AM
