Volvo xc90 t6
Old Apr 15, 2011 | 04:12 AM
gkclassicauto's Avatar
Default Volvo xc90 t6
Dear friends,
I got a volvo xc90 t6 on 2004 Model.
In the dash board i saw the message "Transmission Service Urgent" and then i checked with autoboss scanner and the fault is comming about Solenoid S1 faulty then i open the transmission and change the solenoid s1 after that i fix back the transmission and check again with the scanner and erase all the fault code. Now its coming the different fault code " input speed sensor signal missing" then i open it back and change the speed sensor and fix back .
Surprisely its ok....no more fault code is coming in the dash board. then i go for test drive and keep it 1 night. after next day suppose to going send back the car to customer and unfortunately on the middle way the fault code has came back again......"Transmission Service Urgent"
I check again with the auto boss and now the new fault code is
"0002A-gear3 ratio"
Please try to assist me how do i solve this problem ??
Old Apr 15, 2011 | 09:05 AM
04XC90T6AWD's Avatar
is it the GM-4T65E tranny thats in there or has it been swapped with the volvo tranny? it could just require a reboot? did you reset the computer reload the software?
Old Apr 20, 2011 | 03:15 PM
VolvoTech65's Avatar
You need to do a Glycol test on the transmission fluid. Most likely you will find that the fluid is contaminated with coolant. In this case Transmission, Radiator, Transmission oil cooler and oil cooler lines will need to be replaced. Is. there any debris in the oil pan? Definate sign TU=replace.
jefflee137
Apr 22, 2017 03:12 PM
zral
Sep 27, 2009 01:48 AM
chinaman
Oct 28, 2007 10:18 PM
Bosshoff
Oct 26, 2007 05:09 AM
kim
Jul 8, 2006 01:37 AM
