Window: auto up feature reopens window!
Old May 23, 2009 | 01:30 PM
MIK911's Avatar
Default Window: auto up feature reopens window!
Recently the driver window of my 06 xc90 doesn't stay up (closed) when using the one touch auto up feature.
When i click the auto up switch, the window goes up to the top, then reopens (window down) to the previous position that the window was at (eg half way down).
I searched, and tried to 'reset' the brain/actuator by holding the switch in the down and/or up position for 10 seconds, but no help.
Any other suggestions, or is the brain/actuator broken?
Old May 23, 2009 | 07:05 PM
m1964's Avatar
nothing is probably broken-window lift motor/switch needs ajustment, done by dealer only.
Old May 27, 2009 | 11:09 AM
lysleolive's Avatar
MIK911,
I had the same problem, there is nothing wrong with the window, the dealer just reset the window for me. M1964 is right on the money.
They didnt even charge me.... but I guess thats up to the dealer.. goodluck
Old May 28, 2009 | 12:06 AM
MIK911's Avatar
thanks for the info.
odd that the 'auto up' feature must be 'adjusted'. never had this happen on any other car before.
Old May 29, 2009 | 10:34 AM
m1964's Avatar
Last time it happened to our XC90 I asked service "advisor" why the window suddenly needs adjusment , and he replied with very irritated voice: " I worked at many other dealerships, it happens to all cars, not just Volvo!". on my way out I thought "never happen to Honda Pilot..."
Old May 30, 2009 | 12:11 AM
MIK911's Avatar
Word.
m1964--You have PM
Old Jul 9, 2011 | 08:03 PM
rpineda's Avatar
Just fixed my XC90 '05 driverside window based on a post
Swedespeed Forums - how to do power window calibration?
Took two minutes to do!
Thanks to this, LTA!!!
Old Sep 9, 2011 | 11:17 AM
bantambouncer's Avatar
SPOT ON, the easiest fix i've ever done, took less than 10 seconds, opened the side dash fuse box look for thye right fuse for my door (36 i think for drivers side) sent my window down, when it was in motion i took the fuse out, put the fuse back in then sent the window to the top, held the button in the up postion for 5 seconds and that was it, less than 10 seconds to fix :-) HAPPY DAYS.
Old Sep 25, 2013 | 12:44 PM
ticedoff8's Avatar
This worked perfectly on my 2002 S60 T5.
It was fuse 27 on my car.
The body shop replaced the window and it started acting strange. They said take it to the dealer. The dealer wanted $50.
It took me longer to find the correct fuse than it did to run the procedure.
Old Aug 20, 2016 | 11:50 AM
LuisM's Avatar
Just did this....
1. Engage the auto-down function and remove fuse during window movement.
2. Install fuse back into position.
3. Engage the auto-up function and hold it engaged for 5 seconds after the window has reached the fully closed position.
4. Verify window is now working properly.
Worked so far...
Old Aug 20, 2016 | 09:02 PM
arfstrom's Avatar
Hmmm, I had a check engine light on, So I asked them to fix it too. (my dealership has a complimentary check engine light for up to 1 hour policy) I like how easy this is,
Old Feb 9, 2017 | 10:08 AM
Thunderchild's Avatar
Man great information on this site. My wife's XC90 is doing this now. I will apply this fix.
roblinds
Jul 7, 2014 06:22 PM
cdnbluez
2001-2013 model year XC70
Jun 11, 2014 11:26 PM
tom98s70
Mar 7, 2012 10:47 AM
bond007
Feb 5, 2011 09:34 PM
rezmoto
Jan 28, 2009 06:53 PM
