2004 XC70 Window regulator slide replacement "auto" feature not working
Old Jan 11, 2014 | 01:09 PM
cdnbluez's Avatar
Default 2004 XC70 Window regulator slide replacement "auto" feature not working
The two arms of the regulator on the drivers door popped out of the blue plastic slides. I replaced them with new ones, but now when I activate the "auto close" function the window reaches the top and then opens all the way again. Is there a fix for this, or do I have to get it re-programmed at the dealer? Auto open works fine. I can close the window but have to inch it up near the end.
Old Jun 11, 2014 | 08:14 PM
madymo3d's Avatar
This happened to me on an 04 S60. I did the reprogramming and it worked fine. I'd imagine xc70 would be same. I forgot how I found the solution, try some different search terms.
Old Jun 11, 2014 | 11:26 PM
damien360's Avatar
Most people claim that if you pull the switch to the close position when the window is closed for 10 seconds it reprograms the window. I haven't seen it work on the older cars personally the only sure way I know of is to take it to the dealer and get it re calibrated
MIK911
Feb 9, 2017 10:08 AM
Equestrian
Mar 5, 2014 04:09 AM
dejr
Jun 25, 2012 10:04 PM
bond007
Feb 5, 2011 09:34 PM
rspi
Aug 29, 2010 01:59 PM
