XC90 awd problem.
Old Dec 1, 2022 | 10:39 AM
Tomas343's Avatar
Default XC90 awd problem.
Hello, I've got problem with my xc90 '07 volvo's rear bevel gear. I changed it's pump ( old one was burnt, i dont even know why), for some time i had a feeling that my rear wheels is not driving as they should. Today i tried to see if my guess is right, and my guess was right. Maybe you know where should I search for problems?
Old Dec 1, 2022 | 11:06 AM
First step would be to scan the entire car, especially the DEM for codes - If there is an electronic problem there should be a code that will give you a hint of what to check. You mentioned the "pump was burnt" - A common problem is the pump shorts out and fries the DEM.
There might be helpful info courtesy of xemodex found on this page https://xemodex.com/us/diagnostic-flow-charts/
anxov1es
Jul 3, 2022 05:44 AM
oabbott
Feb 13, 2017 08:12 PM
oabbott
Feb 8, 2017 07:29 PM
timhixson
Jan 29, 2009 07:32 AM
Andrewde
Oct 30, 2008 12:51 PM
