xc90 lowbeam headlight turns off when car started
its been 0 degrees or less in Maine for last 4 days (not sure if cold weather is causing this).
A couple days ago i started xc90 after work and the driver side lowbeam headlight went out. Thought it was bad bulb. Later, I turned car off and then turned key to ON position, headlight works.
But, as soon as I start the car the driver side lowbeam headlight flickers (once car is started) and goes out and stays off. Its been so cold that i haven't done much other than check that the harness to headlight fixture isnt loose.
Does this sound like a relay issue? I can't seem to find info that the headlights have a relay. The fuse for lowbeam headlight is fine (checked it last night).
It switches from xenon to regular depending on daylight sensed Canadian vehicle. I never have to touch light switch.
Iggyomega
04-10-2020 07:23 AM
Nightc
06-01-2015 12:51 AM
ohryan19
05-18-2010 06:36 PM
